Herc-U-Lift caster problem????
  • Herc-U-Lift caster problem????
    Love my TS3650 but for one problem - the rear casters will not rotate a full 360, they hit the legs first. When this happens, I have to nudge the whole saw and rotate the casters around the other direction to get it headed in the intended direction. I checked to see if the casters were in a wrong hole in the Herc-U-Lift tubes, but there are no alternate holes?
    Anyone have a solution??????????
    My 3650 did that until I realized that I had not finished tightening the bolts that hold the herculift to the legs. After I finished tightening those four bolts, it is as smooth as silk.
    Hope your problem is that simple too.
    Jim
