BS1400 Bandsaw Questions
  • BS1400 Bandsaw Questions
    I was browsing the manual and came across the Blade changing routine. There were 4 steps before the blade can be removed;
    release tension, remove table pin and insert, remove rear blade guard, and loosen screw for lower blade guard and pivot out of way.
    Is this a big PIA? Is this standard for most bandsaws? What the hec is the table pin for?
    I turned my rear blade guard around so the open side faces the front now. Sure does make it faster to change blades.
    SSG, U.S. Army
    K.I.S.S., R.T.F.M.
      Hector, the pin keeps the 2 halves of the table top inline with each other so one does not sag and catch the wood as it passes over the crack between them. The lower gaurd piece I just left off.
      info for all: --- "I like long walks, especially when they are taken by people who annoy me."
        Thanks for the replies guys. You'll probably be seeing a few more posts from me in the coming weeks as I get closer to purchasing the saw.
