Storing table saw
  • Storing table saw
    Would like to move table saw to unheated building. N W Iowa winter. Building is tight, no roof or wall leaks, but it will be cold. Saw has a cast iron table. What is the best way to avoid rust and other problems? TIA jps
    This stuff is a great rust preventative:
    http://www.theruststore.com/Boeshiel...osol-P3C4.aspx
    Jim.
      Storing my jointer and DP in unheated garage this winter as well, I used the T-9 as well, just spray on a good coat and leave it, it will take a few days to dry but will form a nice thick protective coat. When you want to use the saw again just mist again with T-9 and wipe off the access.
        Storing table saw
        Thanks much, guys!!! Looks like I had better get some T-9 ordered. jps
