New Shop
  • New Shop
    http://www.jsm4u.com/shop.html
    Well heres a link to the my new shop in the works
    floor is in now were working on the walls and front area of the barn.
    What a pain 80 year old barn with rough cut lumber trying to make thing meet-up just dont work had to tare out the whole front of the barn just to frame it back in now.I'll post some more pics later as we go along.
    Any ideals on a good lay-out for a 20x48 floor ??
    GRIZZLY.COM HAS A WORKSHOP PLANNING FEATURE WITH SAMPLE TOOLS SO YOU CAN EXPERIMENT WITH DIFFERENT ARRANGEMENTS QUICKLY. HOPE THIS HELPS.
    IF YOU\'RE WORKING HARD, YOU\'RE DOING IT WRONG
      I'm jealous !!!
      One thing is you said 'swamp coolers' are these true swamp coolers ? where i'm from that means water evap which would be putting moisture into the air... not good for tools !?! Maybe look into some mini split heat pump units by NRP or Sanyo or the like
      just my $.02
      Ted
        Thanks toolguy1000 I need to check on a new lathe form grizzly anyways so I'll check there shop plans.
        Thank dietz I never thought about the moisture in the air I'll have to check into the NRP or Sanyo heat pump units
