Router Table - Portable or TS mount?
  • Router Table - Portable or TS mount?
    Hello everyone, I need your opinions on which to purchase. First off, I have the Ridgid 3612 saw (love it) and do woodworking as a hobby. I was looking at the Benchdog 40-001 benchtop model for $199 or the Mulecab saw mount with fence for about $10 more. I'd like to stay around the $200 range. Is there alot more advantages to one than the other? Your opinions would be much appreciated. Thanks
    I bought a portable table and will make a cabinet for it this year out of the scrap i have in shop now. Hope that gives ya ideas...
      If you mount your router in a tablesaw extension, you will not be able to use them both at the same time. I am not organised enough to do all my tablesawing at once and then all my routing at once. I could never put up with having to repeatedly set up one tool and then the other. The other thing about having a router hanging from the tablesaw is that it isn't easy to control dust from the router since it isn't enclosed (usually).
        I put an extension wing in my TS for a router - i have a small shop and needed to save the space. I made it for about 20.00 - much cheaper than commercial versions and i think it would be tough to find a neater fit. Do a search for "TS router table wing" and you'll get the right threads with pics.
        Shipsax and other have lots of great pics posted.
          I thought about the table saw mounted router but decided to scavange around and build a seperate table. I use a pair of Porter Cable 3hp 5speed routers for making doors, stlyes and rails. I hated the set up time so I decided to squeeze in two of them and a Delta power feed (real time saver! and cheap too.)
          The power feed is for running the edges. Seperate vacuum holes makes switching back and forth a breeze too.
          I used some old maple butcher block I had from a top I made years ago but did not use. The rest is just scrap 3/4" ply from the pile. Fences are scrape maple from a job too. It's easliy movable and goes in the storage area out of the way when not in use.
            this is what i did with my 3650. i like the extra room it gives me and i use the ts fence with my router table. i have a freud 1700 router in it and it makes it easy to lower the bit in case i have to use the saw.
            rbClick image for larger version
Name:	ts3650 router table.jpg
              Re: Router Table - Portable or TS mount?
              Thanks for all the great ideas. I like the dual router design table, very nice. I decided to go with the Bench Dog portable table, this looks like a very solid setup. I recieved the package the other day and started to assemble the table when I noticed a small hairline crack in the laminate top from the rear slot to the outside edge. I immediately called them and they are sending a replacement top out right away - no questions asked. This is what seems to be a very good company with great customer service. Thanks for everyone's input on this topic.
