New TS2400LS
    Re: New TS2400LS
    Great information on the making of the ZCIs, Papadan. That Ridgid ZCI looks a little like the underside of the standard insert. I'm led to believe from some other how-to instructions I saw, that if you make a thicker (1/2 inch?) insert rabbetted to fit into the opening, you may not be able to raise the blade all the way without the arbor contacting the bottom of the insert. And that additional routing may be needed across the insert near the middle to provide clearance for the arbor. (Although, you wouldn't be raising the blade ALL the way for most cuts.) It doesn't look like there's anything special on the Ridgid insert. I'll have to remember to measure the distance from the top of the arbor to the top of the table to be sure I don't make anything too thick.
    Ray
