Router Table problem
  • Router Table problem
    I recently built a router table for my new ridgit router. The only problem I seem to be having is getting the bit centered on the brass bushing. I used the clear plastic piece off the bottom of my plunger and routed a hole for it to fit flush into the table. I then screwed 1" screws through the table and base plate into the router. When I adjust the depth of my router and tighten the base back up it throws the bit off center. It isn't much but I really want to make some tight fitting dovetails. Any suggestions?
    Re: Router Table problem
    It sounds like you are attaching the router directly to the table, correct? I used a lift/insert plate that bolted to the router then that whole assembly attached to the table.
    FSK
      There is a centering cone and pin that is supplied with your router. While it is intended to aid in properly mounting the baseplate to the router, I would think it would be handy when mounting the router to anything else.
        Thanks guys, I am going to get the router plate. I was hoping to skip that step and avoid the extra expense but I guess it is the small things that make the difference.
