surface rust
  • surface rust
    I own a 3650 table saw and have some surface rust on the table, how do i rid myself of this problem
    Re: surface rust
    omg it's rust!!!! ahhh just clean of the top with some steel wool then aply a few coats paste wax
    9/11/01, never forget.
      Re: surface rust
      You also have to make a sacrifice to the rust gods.
      A small piece of cast iron and a drop of blood from one of
      your fingers is all that they require for the first offense.
      Just don't let it happen again
        Re: surface rust
        Wouldn't steel wool scratch the surface. Perhaps the Scotch brite stuff would work better.
          Re: surface rust
          Not really, just make sure to scrub in the direction the top is machined. WD40+steel wool works very well for me. I also tried Boeshield T-9 as someone here recommended and it worked awesome on the cast iron table of my jointer. You can get it at Sears. Its a little expensive but well worth it. Comes in two bottles, a rust remover and the lubricant/protectant which does a really great job of holding back the rust.
            Re: surface rust
            If the rust is really bad, which I have had in a few places but not anymore, I ues 220 grit sand paper on my random orbital sander, then hit it with WD40 and 00 steel wool then finally with 0000 steel wool. Cleaned the oil off the top and put 3 coats of Johnsons Paste Wax on, buffing in between coats. I now have a slick mirror table top to my TS3650 table saw.
