Router bit for regrooving 3/4 strip flooring?
  • Router bit for regrooving 3/4 strip flooring?
    Hello-
    I'm in the process of reflooring a section of hardwood floor that was badly stained. After I took up the strips I took the nails out of them, and chopped off the stained areas with a miter saw. There's plenty of good wood left over, but since they're only pieces, the tongues/grooves are missing from the sides.
    Does Home Depot/Lowes sell a router bit to regroove/retongue standard-sized 3/4" thick wood?
    Thanks.
    -TM
    Re: Router bit for regrooving 3/4 strip flooring?
    I think Woodline Az. sells a T&G set.
    Only a surfer knows the feeling. Billabong ca. 1985 or so
      http://www.mlcswoodworking.com/shops...aneling_anchor
      http://www.rockler.com/product.cfm?page=2134
        Thanks for the replies!
          Just and FYI, becareful of tear out on the end grain. I installed a fir floor and used a rabbit bit to put tongues on the ends of some boards going into a breadboard edge, and I got a lot of tear out. I would have been better milling them on my tablesaw, making a relief cut first.
            or you can just use a backer-board....
              Well, I WOULD have done that if I had remembered it! Live and learn (again and again and again...)
