Circular saw recommendations
    Re: Circular saw recommendations
    I also have a Porter-Cable 743K left-blade sidewinder, and I must admit it's probably the best sidewinder out there. It's powerful (as far as sidewinders go anyway), lightweight, and best of all the blade is on left side (the way a real saw should be!)
      Originally posted by zenophus View Post
      OH Yeah......almost forgot. Until someone comes out with a cordless that can make it through a 96" plywood rip without pooping out I would STAY AWAY from cordless.
      ahhh the advances in technology...
      http://www.milwaukeeconnect.com/weba...0028&langId=-1
        Originally posted by rnt80 View Post
        I'm not necessarily looking for battery power. It will primarily be used for finishing work. Cordless would be nice when I take it out but that's not high on my priority list.
        If you want a small but powerful trim saw, nothing beats a Skil HD5510 5-1/2 (again, blade-left). It' a work horse. I've even used it a few times for framing when my worm drive was MIA.
          The little yet great SKIL circular saw:
          http://www.skiltools.com/en/AllTools...510&cid=192162
          Here is another 5-1/2 inch model to check out.
          http://www.makita.com/menu.php?pg=pr...det&tag=5005BA
            Yeah, I don't know why Skil always includes a POS steel blade that's is going in the trash out of the box!
            The only problem is the limited selection of 5 1/2" blades...
              I have been using skill saws for years and i have found Porter Cable to be the best.
              They are not as heavy and have lots of power with a 15 amp motor.
              John from Belgrave ont.
              www.extremebirdhouse.com
              http://www.facebook.com/?ref=logo#!/...d=112698715866
                get a ridgid worm drive its great
                • #23
                  Worm saws are great for cutting plywood but if your cutting rafters for 3 or 4 hrs at a time your arm will be licked using a worm saw.
                  When i built houses i had both types of saws for that same reason.
                  • #24
                    Why get rid of the wormdrive when all you need to do is get bigger arms?
                    • #25
                      you bet newman
