Biesemeyer fence system
  • Biesemeyer fence system
    Hi all.
    I wanted to ask, has anyone installed a biesemeyer fence system on your TS3650. If so, what model did you buy( Part number).
    Did you hve to alter the table saw in any way or drill anywhere to install it?
    I tried searching for this info in this forum, but I don't see any specific information on the subject.
    regards,
    olilugo
    Re: Biesemeyer fence system
    all I did was type in your header on search up above, there is more than this one, but go ahead and read. I won't be changing mine, because I like mine, anyhow good luck...
    http://www.ridgidforum.com/forum/sho...r+fence+system
      I did all kinds of searchs like the one you just provided , there are lots of post mentioning Biesemeyer in one way or another, however none of the post mention what Fence part number they purchased and whether they had to alter the table itself to install it.
      I was hoping to get an idea as to the actuall part number people used, unless the answer any of the parts will work and the only difference is the lenght to the left and right.
      olilugo
        This information from Biesemeyer should help you
        http://www.biesemeyer.com/commer_fence/index.htm
        They have an 800 # to call on that page.
          Yes I installed the http://www.mikestools.com/B79-016-Bi...ce-78-100.aspx
          I did have to drill some holes in the front and rear and enlarge the hole for the Blade guard.
          There is a model specific to the Ridgid saw. I would assume that it fits without modification. But then I have been wrong before. http://www.mikestools.com/B78-322w-B...ce-78301w.aspx
          I am very pleased with mine.
            Wkent,
            Thanks, this is exactly what I was hoping to find out. Thanks for taking the time.
            olilugo
