Buying WW vise for workbench
  • Buying WW vise for workbench
    What is a good jaw opening size for woodworking vises as I am planning to build a workbench. There is one from Canadian Tire on sale for $14. The jaws are 6" wide and a jaw opening of 4". I assume not including the liners.
    I just want to make sure that I buy the right one the first time and not find out till later that it is too small and use it as a paper weight.
    http://www.canadiantire.ca/browse/pr...romSearch=true
    I
    Re: Buying WW vise for workbench
    I use the little vises just as much as larger, maybe more.
      diesel,
      I have the same size you are refering to. You are correct, liners are not included in the opening measurement. I use mine quite often and haven't concidered anything else. I do use my hand held clamps more often than the vise, I usually clamp to the workbench surface. Hopefully someone else has other opinions to help in your decision.
      If at first you don't succeed, try reading the owners manual.
        I have one very similar to what you're considering. While it's quite handy for many things, I'm considering something along the lines of the Veritas twin-screw, http://www.woodcraft.com/family.aspx?FamilyID=3077 . I'd like something bigger and more functional. My problem is, the workbench drawer is at the open end of my workbench! I need to either reconfigure the bench, or build a new one that will take vices and be drilled for hold-downs and bench dogs.
