dust collectors again
  • dust collectors again
    ok guys what about this unit, I am in canada should be able to do the job looking for opions......
    http://www.bosstoolsupply.com/index....OD&ProdID=9420
    §m€llŸ™
    Re: dust collectors again
    If you can swing it, look for something that has the pleated filter for the top instead of a bag. Personally, I find the pleated filters are much better at the fine particulates from sanding. I have the Jet 1HP:
    http://www.woodcraft.com/family.aspx?FamilyID=2055
    I got the model "A" shown there with the remote control. You might be able to find something like the Shopfox pleated filter top section for the Delta you're looking at. Just something to think about.
      As long as you're not planning any long runs of collection ducting that unit should work just fine. Do you plan on moving it from machine to machine as you need it or will it be hooked up to a number of tools?
        no Badger I dont plan on moving it around
        §m€llŸ™
          In that case, get the highest quality blast gates that you can afford. In order for your DC to operate at its best you'll need to make sure you're not drawing air from branch lines that are not being used.
            http://www.kingcanada.com/Products.htm?CD=19&ID=895
            I think I will go with this model a little cheaper than the one I posted in the first post on this thread....
            and comments will be appreciated
            will have to order it from toronto.
            §m€llŸ™
              Buy self cleaning blast gates at Lee Valley Tools they have nice metal self cleaning gates 4" are about 12 dollars and they sell clear pvc hose also.
              You may want to check out Busy Bee Equipment also, i think they have their 2 horsepower dust collector 1600cfm on sale for around 400 canadian.
              CoolPix
                hey thanks cool pix
                here is a liknk to what I found
                http://busybeetools.ca/cgi-bin/pictu...3&NTITEM=CT030
                looks interesting
                §m€llŸ™
                  I have the same unit just a little older, works great.
