image posting
  • image posting
    ok this is it in the basement , unpacked and ready to do inventory, you can just barely see the table extensions under the main body. Lighting was a bit poor.
    §m€llŸ™
    Re: image posting
    yup -she's a heavy beast. Make sure you wear work gloves when assembling it to avoid rust marks on teh cast iron (and don't put your coffee on it like i did).
      Re: image posting
      I have some images of out side in the truck, but they are 1600 x1200 and the file is too large to upload to the forum, is ther a way to change it to small er size ?
      §m€llŸ™
      §m€llŸ™
        Re: image posting
        if you have photoshop just change the image size so that it takes upless space - 75 dpi is all you really need
          Re: image posting
          If you don't have Photo$hop, Windows Paint has a resize utility. Open the pic in Paint, select Image from the menu, then select Stretch/Skew, then reduce the horizontal and vertical by the same amount (%).
          - djb
          A Democracy is 2 wolves and 1 sheep voting on what to have for lunch.
          Restore the Republic.
            Re: image posting
            Get yourself the free program, Irfanview. You can resize easily with it. Open the picture with irfanview, go to the Image menu, select Resize/resample. I use 640x480 for most of my pics. They upload fine.
              Re: image posting
              ok here is the arrival to the bk door
              §m€llŸ™
                Re: image posting
                oh oh file was still to large
                §m€llŸ™
                  Re: image posting
                  Smelly: Go to this site, and resize your photo to 600 pixels. That sould work!
                  http://www.shrinkpictures.com/
                  Brian
                    Re: image posting
                    change the pixels on the camera.
                      Re: image posting
                      yes I changed the pixels on the camera
                      its down to 800x600
                      §m€llŸ™
                        Re: image posting
                        I will reduce mine down to 640 with Irfanview, however my file size will still be to large, so I need to reduce my pictures down to 300, in order for my file size to fit. Also camera pixel setting is at the lowest setting, which I think is 800. So you might have to look at your file size, this might help. Irfanview is so simple to use, maybe this should be a chat room discussion, camera's and pixels and programs.
