14" Band Saw
  • 14" Band Saw
    I had gotten the 14" Bandsaw. And after reading in WOOD, I thought it would be a good ides to get the riser block. I had a very hard time looking on the Ridgid web site and if I found it correctly, then they want $153 for it. So much for WOODS article stating it shoulent cost more then $80-100 for it. Has any of you found one cheeper?
    Re: 14" Band Saw
    Yes, many have. Grizzly has one that will fit the Ridgid BS for somewhere in the neighborhood of $60. Use the search feature near the top of the page and use riser block as your search subject. I'm sure that you'll find the Grizzly model # in one of the threads.
    ------- Henry Ford
      Re: 14" Band Saw
      Boy I feel like I got a bargain. When I bought mine I got the saw, fence, and riser block all for $369.
        Re: 14" Band Saw
        Thanks for the feedback. I found the riser block on Grizzley. Now I just hope it will work on mine.
          Re: 14" Band Saw
          Be sure that it is a complete kit and not *just* a riser block. You will need two, longer blade guards, a longer bolt to hold the upper and lower halfs of the machine together and the height adjustment bar which raises/ lowers the blade guide blocks and the bearing. I haven't looked into the Grizz - just offering a potential 'heads up', as it were.
          Later,
          Chiz
          Later,
          Chiz
