selecting the correct door left or right?
    Re: selecting the correct door left or right?
    Locking hinges have a set screw that keeps the hinge pin from being pulled and can only be loosened when the door is already open. There may be other types but a good set up Ive seen is where hinge pins at the top and bottom are locked this way and the center pin is not removable at all so you can still hang the and unhang the door with the pins loose but screw the center hinge in place once the top and bottom pins are in place. Chances are once someone is going to go through the trouble of messing with the hinges they will find a easier way in anyway, ie windows etc.
