Bosch T&G router bit
  • Bosch T&G router bit
    Why is it when i use my bsh. T&G the 1/4in MDF. is to thick , enough to split the grove . my mic tells me its 5/32 not 1/4 . (that's mean) anyway ill be making raised panel cab. next .
    Re: Bosch T&G router bit
    Usually MDF machines well although brutally dusty. Does your bit have shims that you can remove? what does your mic tell you about the spacing between the tongue cutters?
