Finishing a maple butcher block
  • Finishing a maple butcher block
    I have a maple butcher block that I aquired and am refinishing. If I intend on using this as a food prep surface, should I only use oil specifically for butcher blocks?
    Also is there such thing as a non-toxic stain that I could use to add some color to it, then oil over it?
    Thanks for any help!
    -R
    Here ya go. And welcome. [img]smile.gif[/img] http://www.rockler.com/ecom7/product...0bowl%20finish
    Lorax
      Thanks Lorax! Perfect info!
        Also take a look at these, there are some tints that will add some color.
        http://www.rustoleum.com/product.asp...t_id=112&SBL=1
          Oh great, thanks! That's very helpful.
          -R
            cutting board
            The cooking shows a suggest you use warmed mineral oil as vegetable oil will turn rancid. As far as adding a tint I am also looking for a non-toxic way to add color to the maple.
              I don't know if this is a good idea or not, but here it is. Could you use food coloring to tint the maple?
              kevin
