Help with Blown out Mortise on Sjoberg
  • Help with Blown out Mortise on Sjoberg
    Hi,
    I hope someone can give me advice, I'm a newbie who made a stupid mistake!
    I bought a Sjoberg 1660 workbench from Rockler. Two of the Mortise and Tenon joints for the legs were over-sized, the tenons length were over 1/10" over-sized. I hammered it in and it blew the side out. I chiseled out the other one. The pictures will show by not much, but even though it doesn't seem to be weak I want to be assured that the joint won't give out in the future plus it's right under the vise.
    So I'm looking for advice on how to secure this. I found a plate. that is 1/16" thick. I was figuring on using a plane to level the blow out and then chisel a mortise 1/16" for the plate.
    BTW, as I mentioned I bought this from Rockler, I'm happy with their service, I received it in less than 1 week and they did a great job in reinforcing the box. I originally bought the workbench from tool-corral.com. If you're interested read my review of this online store and be warned.
    Thanks,
    Phil
    Re: Help with Blown out Mortise on Sjoberg
    Not seeing what you are asking. Looks like you chiseled off the tenon?
    If the boards are not split you could chisel out 2 mortises and then create a separate tenon to join the boards
      The blown out piece is the one with the mortise that received the tenon from the one on top of it.
      Phil
        Got it. You will loose some of the mechanical strength provided by the M&T joint but most of the strength is provided by the glue. If you use a good quality wood glue you will be fine. You could drill holes and insert two 1/2" hardwood dowels down from the top of the joint
          Agreeing with Wayne, here. As long as that blown out piece is solid - and I mean *solid*, you're OK but I would test it. Tap it with a hammer from different sides and be sure it doesn't move. If it does you should remove it, reglue and push it back in. Find a way to clamp or add weight to it and it should be all good. I wouldn't sweat the dowels. There's 90% of that joint still on duty.
          Later,
          Chiz
          Edit: I'm assuming that you plan to cut that blown out piece flush with the end.
          Later,
          Chiz
