TS3650 to Vacuum
  • TS3650 to Vacuum
    OK, I just bought the Ridgid 12 gallon shop vac (the 1246). So exactly what size connector do I need to connect the hose to the dust fitting on my TS3650? If you know the size of connection, please tell me whether you're talking about inside or outside diameters of the fitting.
    Thanks very much in advance for your help.
    Terry B.
    Re: TS3650 to Vacuum
    If the hose is 2.5 then it should just mount up no problem. I it is not they sell conectors from smaller to larger and vice versa . My hose installed no problem and is 2.5 on my 16 gallon vac.
      I believe it's 2.5 O.D. Using the vac will be a huge help to you. Incidentally, I routerd some PVC from the shroud fitting down to the leg for easier access. I had to reduce the elbow at the end where I connect the vac because of the difference in diameters. Not pretty but still OK. The downside to this set up is that you have to disconnect it when you need to tilt the arbor. Not a big deal for all the more often that I do that.
      Later,
      Chiz
      Later,
      Chiz
