Router Table on TS2424 ?
  • Router Table on TS2424 ?
    Has anyone mounted a Router table on the left side of their TS2424?
    I am thinking of making a 12in table and mounting it on the left side along with the cast iron wing. This way I will be able to use my fence along with my router mounted underneath.
    Any ideas or suggestions?
    ssg57 I've been looking for a router table for my TS-2424 for some time. I think I've found one that will work. It takes the place of the left side table wing. If you go to www.benchdog.com you should be able to fine it. I think it cost about $300.00. You might also check out www.woodmagazine.com they come up with some nice add on for table saws. Like a folddown outfeed table, they use the TS-2424 as a modle for these add on. I hope this has been some help. If I come across any thing more I'll add a post or email you if you email is on file at this sight.
    Rergards Daniel Maloney
      Daniel,
      You may want to check out "Rockler" Woodworking & Hardware www.rockler.com I seen a router table in there also.
      My e-mail is ssgrant@prodigy.net if you run across something of interest.
      Thanks Scott
