HF Dust collector Promotion codes
  • HF Dust collector Promotion codes
    Does anyone know what the promtion code is for the HF DC model#45378-1vga, and much the promotion code is for? Any help would be great.
    Thanks
    Ben
    I just ordered one yesterday myself. The trick is that you have to use the "Order from catalog" link on the left side of their home page. Then you want to enter the item # as 45378-2VGA, then click on the add to cart button.
    That should get you the $119.99 price instead of $199.99.
    FYI, there is a huge thread about this DC on the Woodnet forum that you might want to check out.
    Kevin
      Ben,
      If you do check out the thread on Woodnet, we'll see you back here around April 20!!!
      David
        David,
        From what I read on the Woodnet thread, April 20 is probably about when his DC will arrive anyway. [img]smile.gif[/img]
        Kevin
          I recieved mine after about 11 or so days total from the time I ordered it, backorder, and delivery. Set up was about 45 minutes. Haven't used it yet because I had to go Jeep'in this weekend, but will connect everything this week and see how it works.
          Rob Johnson
          Orange,Ca.
          Just tilt your head a little and it will look straight!
            Your number brings up $199 now.
            I guess sale is over
              I just tried the 45378 2 VGA code and it said $119.99...
              Still works...
              Try entering the code in here: http://www.harborfreight.com/cpi/taf/catorder.taf
              [ 03-03-2003, 10:01 AM: Message edited by: Big Johnson ]
              Regards,<br /><br />Big Johnson<br /><br />Pictures: <a href=\"http://www.woodworkersweb.com/modules.php?set_albumName=albuv85&op=modload&name= gallery&file=index&include=view_album.php\" target=\"_blank\">http://www.woodworkersweb.com/modules.php?set_albumName=albuv85&op=modload&name= gallery&file=index&include=view_album.php</a>
                Big Johnson
                I must have the wrong zip or some keeps coming up $199 and the number changes to 45378 1 VGA. I put in 45378 2 VGA
                  How about just calling them with the order... Tell them you were given the code from a friend... [img]smile.gif[/img] Here is the phone number 800-423-2567 and the code is (45378-2-VGA)...
                  See what they say...
                  Here is my HF-DC...
                    Big Johnson
                    Thanks for the help. I got the order to go through online. It would not take it on the regular site you had to go the catorder site.
                    Once I got there it worked. That was the slowest site I have been on since I went dsl.
                    Thanks again,
                    SCwood
                      Glad it worked for you... Enjoy your DC...
                      Mine has worked very well since I got it...
                      The motor runs very, very smooth, (but) if the motor ever let's loose, I have big plans for it...
                        the promotion for HF DC is no longer valid...The price is showing 199.99 even on the cat order form. Which DC would you guys recommend now..and where would be the cheapest place to purchase it from.
                        Thanks
                        Ben
                          Just checked the HF website. It appears they have deleted #45378-2-VGA @ $119.99. HOWEVER, I played with the numbers & you can still get this DC for $139.99. The code to use is 45378-6-VGA. Remember, you have to enter this code on the "Order from catalog" screen for it to work.
                          If that one doesn't work, you can use ...3-VGA to get $149.99, or ...5-VGA to get $159.99.
                          Haven't received mine yet, but will post when it finally comes.
                          Kevin
