zero clearance insert for TS2400LS
  • zero clearance insert for TS2400LS
    where can i find a zero clearance insert for my ts2400?
    here a link to the inserts. http://www.ridgidforum.com/cgi-bin/u...c;f=5;t=002404
    Andy B.
      First you need to identify whether you have the newer or older ts2400. If its ornage and has t-slot miter gauge you can use the same as those used on the TS3650. When Ridgid started putting a t-slot they had to thicken the tops of these two saws and the inserts are thicker then on older models to accommodate this. If your saw is gray and doesn't have the t-slots, the inserts for the TS3612, TS2424 or TS2412 will fit.
