Attaching wood to rip fence for use with dato blade
  • Attaching wood to rip fence for use with dato blade
    I just bought the TS2424 and I am looking for the best way to attach a board to the rip fence for use with a stacked dato blade. My old saw had screw holes for this purpose.
    Any ideas? (Knew you would...)
    Dwight
    A square head bolt works, but if time is an issue you can use clamps. oh it's dado not dato. Just trying to help.
    [ 05-20-2002, 08:37 PM: Message edited by: Andy B. ]
    Andy B.
      Just make sure that the piece you use as an auxilliary fence is straight, else you're going to have all sorts of problems. I tend to use a bit of plywood scrap.
        Dwight,
        There should have been 3 square headed bolts that were included with your saw to mount an aux. fence. If you cannot find them, you can order them from www.ridgidparts.com . The part number is 159653-3.
        Jake
          Andy, Robert and Jake, thanks very much!
          I found the bolts and I'm off and running.
          There's something very gratifying about spending and evening with your stacked dado blade!
          D.
