Upholstery and staples question
  • Upholstery and staples question
    I now have two size staplers.
    A 1/2" 20 gauge and a 1/4" 18 gauge
    Which size stapler do you experienced upholsterers use?
    I will be redoing the padding arms of a water bed. The frame is cheap! particle board, then 1/4" foam wrapped around and finally some new virgin naugahyde.
    I will use 3/8" or 1/2" long staples.
    Cactus Man
    Re: Upholstery and staples question
    All the staplers I've seen specifically designated as upholstery staplers use 3/8 22 ga staples.
      Cactus man: I do a lot of upholstery work on pontoons etc. I use a Porter Cable upholstery staple gun and 1/4, 3/8, and 1/2 inch staples. Got them all (gun and staples) from Amazon. Works great.
      Jim
        Well, I started to reupholster the water bed rails. I am using virgin Naugahyde.
        I really wanted to use my ridgid 1/4" crown stapler..so I decided to go with 1/2" long staples. I set the stapler to the minimum depth setting...
        The good news and bad bad news......
        The Ridgid stapler is wonderful. But using 1/4" crown staples are too narrow and may/will tear the material. I even doubled up the Naugahyde and in a few spots I tore through. I know from past experience using the 1/2" 20ga Craftsman stapler is the wiser choice; but the Ridgid is a cool stapler!
        A limitation of the Ridgid stapler in this project was trying to staple some tight spots. The nose would not engage and I could not fire a staple..Oh well, a few carpet tacks will get those tight spots.
        Oh, as a side bar, I did use the Ridgid stapler to secure a backing of hardboard to a small box I built..The stapler performed perfectly and never a jam!
        Cactus Man
