Hinges: Dowels instead of brass hinges...
  • Hinges: Dowels instead of brass hinges...
    Good morning.
    We are looking for dowels as hinges for cabinet doors.
    Is there such a thing? Does someone sell a dowel hinge system?
    Re: Hinges: Dowels instead of brass hinges...
    What is a dowel hinge system? Are you talking about a hinge system where the hinge pin and bracket are made of wood?
      check with Veritas Lee Valley. I recall them having something. You could probably make your own with a box finger joint and a dowel rod through the joint. 1 Side would have to have a roundover so it would work
        Looking for hidden dowel hinges...no visible hinge.
        We used to use nails on our pigeon coops as kids to get a piece of wood to swing in and out.
          Forgot about something. The dowel pins must be a different wood than the hinges. Otherwise it will wear too quickly
            http://woodworker.com/cgi-bin/FULLPR...ARTNUM=853-357
            I think this is what you're looking for
