Ho far do you stack your TS3650?
  • Ho far do you stack your TS3650?
    I have a few questions on Dado stacks, here we go, I have a Freud Dado stack.
    At about 3/4 inch on the stack I have enough to put on the collar and nut for 5 turns or so. Does anyone use it where the collar doesnt get put on and just the nut? Or whats the minimum you spin the nut on? Its there any general rule to this?
    I also wondered if you should stack the chipper wings opposite of each other or it didnt matter. Say I have 4 on but the way their positioned they seem to favor one side, will the weight start a wobbly? I think the answers no within reason since their spinning so fast.
    Also the shims are a pain in the butt to get off the arbor, you have to work at them, any solutions to this? There so think im not sure drilling them a smidgen wider will be asuch a good idea.
    Thanks
    Re: Ho far do you stack your TS3650?
    The collar washer is not needed when using a dado stack. I never use it when using my dado. If you look in the owners manaul for the saw it says it is not necessary when using a dado blade.
    SSG, U.S. Army
    Retired
    K.I.S.S., R.T.F.M.
      You're correct about shims being a real pain to put on and take off. Here is one solution for you to consider.
      ------- Henry Ford
        Thanks, so the holes on these are a little larger or you dont know?
          Don't know, but it wouldn't be very hard to enlarge them if you'd like too. I would think that a dowel with some sandpaper wrapped around it would make an easy job if it.
          ------- Henry Ford
            Yes they are your arbor is 5/8 and those shims are 3/4.
            SSG, U.S. Army
            Retired
            K.I.S.S., R.T.F.M.
              DOH!
              Technical Details
              • Magnetic
              • Tough, Flexible, and Durable Ceramic
              • Diameter: 3 13/16"
              • Bore: 3/4"
              • Set consists of (2) .010, (2) .012, (2) .015
              ------- Henry Ford
