Assembly table top material
  • Assembly table top material
    Norm, uses a nice simple assebmly table, on every show, does anyone know the name of the material on top? I worked in a machine shop for 6 years and we made plenty of tables using these plastic sheet goods, but I can't remember the name, and I also can't seem to find it at HD or Lowes.
    Is it melamine?
    I bought a sheet of it at HD last week
      I've watched the episode a couple of times and believe it was MDF. Norm has also used Homosote as a cover for his workbench when gluing. I know it wasn't melemine. The assembly table has a plywood top, with the cover screwed on to it, so the cover can be replaced. Personally, for gluing or messy operations, I simply use a small plastic tarp--easy to put on and doesn't take up any room when not in use.
      Dave
        It's solid plastic like material, darkish grey
        "Homosote" thanks, daveferg, do you know where to get it? It's smooth and durable, I'd like to incorporate it on my outfeed/assembly table.
        [ 02-24-2003, 11:14 AM: Message edited by: Andrew H ]
