Steep angles on mouldings
  • Steep angles on mouldings
    What do you guys think is the best way to cut these consistently? Such as,wainscotting that runs on angle with the stairs? Ive watched my boss freehand these many times on his mitre saw,but his hands are oh so close to that blade!! Im not willing to try his method!! Looking for other ideas that would keep me from going to the ER!
    Re: Steep angles on mouldings
    You can make yourself a temporary base with a fence screwed onto where ever you need it. Clamp or screw this base to your miter saw. This is often used when the angle you want can not be obtained by swinging the saw the conventional way...
    Hope this makes sense...
    Cheers! - Jim
      Thanks...im gonna try this method 2morrow,gotta trim out a few trapezoid windows.
