Ridgid Oscillating Sander
  • Ridgid Oscillating Sander
    Today I tried to remove the belt sander to replace it with the spindle and the belt would not come off. Is this common, and what can I do to remove it?
    My suggestion would be to place the unit on the floor and have a partner hold it down while you pull straight up on the belt assembly. If the belt assembly is indeed stuck on and you try to remove it while the machine is sitting on the bench, you may not be pulling straight up on the spindle, which will only make it worse.
    Jake
