closing in General Intn'l table saw
  • closing in General Intn'l table saw
    Hello everyone, I'm new here. I was reading of closing in table saws, and some people are concerned about sawdust left inside the enclosure. I have a good idea. Why not drill a hole in one side of the box, and insert a hair dryer? The fit should be tight. Just start the drier when the vacuum is started, and it will make the remaining particles airborne for the vacuum system to pick up.
    I currently have a plastic accessory resting on the table base edge, and for the most part, it does a pretty good job. I also have a Delta vacuum (1 port)
    and move each time I have to use another machine. I should upgrade and buy a 2 port or more to save all that extra work.
    Paul
    Re: closing in General Intn'l table saw
    Using a hair dryer to blow the sawdust could be a fire hazard.
