Measuring tape is not only for measuring...
  • Measuring tape is not only for measuring...
    Good day
    Well, it looks like the "Doweling on router table" was a little bit "heavy" so, here is something "lighter"...
    I'm sure that you have a few measuring tapes that you don't use but..."lets keep it, maybe one day"...if it's so, you are junk collector like me...
    Regards
    niki
    Re: Measuring tape is not only for measuring...
    Niki, I would say thats a very good idea....
      Bravo Niki !!!
      "It's always something...That's how they getcha'..."
        Niki, you must have stayed up late one night coming up with that Idea
        First question is where did you find a Pink Tape?
        Second question - does it have enough recoil in the spring to pull the cord back?
        Pretty ingenious idea
        Bob
        "I'd rather be a hammer than a nail"
          Thanks for all these really inventive ideas, Niki!
            Thank you so much for your kind replies
            Bob
            You are correct, I was experimenting till quite late with rubber bands and even the dog's leash but it did not work well.
            This measuring tape is of 30 feet but the 15~20 feet, worked for me the same.
            The main problem was that, when I used it from the beginning of the tape, the spring did not have enough force to pool the cord back...that's the reason that I folded the tape a few times till I got the required force to pull the cord back...
            The pink tape is from....the 100 Yen shop in Japan (around 90 Cents).
            Regards
            niki
              niki,
              I think your use of clamps is creative all in itself. I also like the idea of the "drop" power extension cords. Nice work! Gratulacje
              Jim
                you can buy retractable extension cords that hang from the ceiling but they are quite expensive. What an awesome way to make your own. Keep up the good work!
                  wow bro ur a genious
                    If you liked that idea, do a Search of Niki's threads and be prepared to be amazed. He's one talented fella!
                    ------- Henry Ford
                      That is so usefull! and totally inexpensive. I wear the print off the front of about 3 tapes a year, so this is awesomme.
                      Greetings from Norway!
                        As usual great idea Niki. But I do have one questions, how long does it take to get everything out of the way when you want to use the garage door?
                        Charles
                          Thank you so much for your kind words
                          NW Diver
                          I know that you are kidding but...
                          Well, here in Poland it's better if your car doesn't stay outside for the night for 2 reasons...
                          *If it's winter, you'll not be able to open the door at the morning...
                          *If it's summer, you might not find the car at the morning....
                          So the car must go in every night and I'm already used to "clear the area"...it also helps to keep the garage clean because I just go with the vac all over the floor and by that, having a clean floor at the next day of work...
                          So here is the garage just after "clear-up" and the second pic, with the car inside...
                          Best regards
                          niki
ID:	619818Click image for larger version
Name:	Car garage.jpg
                            Yep, I was joking, you really have one laid out shop. Cool.
                            Charles
                              NW Diver
                              Best regards
                              niki
                              [ATTACH]8438[/ATTACH][ATTACH]8439[/ATTACH]
                              lol i forgot people keep tools in there garage
