Wear plate on TP1300
  • Wear plate on TP1300
    Hi,
    I have had my TP1300 for over a year now and have been quite satisfied. Over the past summer I have run quite a bit of rough cherrywood through it and now I notice that the planer bed, known as the Wear Plate in the parts list, seems to be depressed in the center so that the ends now stick up a little higher then they did when new. This seems to have resulted in more snipe.
    My question is has anyone else experienced this problem, and hopefully to Jake from Emerson is this plate covered under warranty, or does the name wear plate signify that it needs to be replaced after a period of time? I would hope that it wouldn't normally need to be replaced after a year.
    Richard
