Lathe purchase, no knowledge
  • Lathe purchase, no knowledge
    Last week I ordered a Variable Speed Mini-Lathe from Steel City - Model 60100 with the bed extensions - it should be here next week. I have absolutely no knowledge about lathes and would like to learn. Because they are small, I thought a good first project would be to attempt to learn to turn pens.
    Can someone suggest a book that they have found helpful for learning about lathes, sort of like " Lathes For Dummies?" Also is my pen project a good first project or are there projects better suited to the novice?
    Thanks,
    Tom
    Re: Lathe purchase, no knowledge
    Tom I don't know if there are many turners here on the Ridgid forums, but I do know that there are a bunch of over @ Family Woodworking.
    There are a bunch of pen turners and knowledgeable folks there who can suggest good books etc.
    Hope that helps
    Cheers! - Jim
      Thanks,
      Tom
      I, too, JUST got into pen turning as my first lathe projects (I've done two now out of walnut!). I don't know if you have one close-by, but the folks over at Woodcraft were very accomodating with my questions and gave me a thorough walk-through on the process, the needed hardware, tools, and accessories. Take a look at penturners.org . Good luck and happy turning!
        Here's a good online walkthrough on pen turning, from cutting the blanks to the finished product:
        http://www.hoistman.com/HoistMan/PenTurn.html
        It's really readable, has lots of pictures, and is practical. The only thing I chose to ignore and buy a dedicated accessory is the pen blank drilling jig. I got one from Rockler, which is great and wasn't expensive.
          Woodcraft has complete instructions online for each of the pens that they sell. Here's an example:
          http://www2.woodcraft.com/pdf/77B98.pdf
          You'll have to by the mandrel which is universal for any pen you make. You will also need to buy the bushings for each pen design.
