"Rolling" Tenon jig for TS
  • "Rolling" Tenon jig for TS
    Good day
    It's a small variation of the normal "fence mounted (ridding) tenon jig"
    For the center part I used two 1-9/16" counter top boards (chipboard covered with Formica) and for the sides 3/4" plywood covered with Formica (everything from left-overs).
    As Vertical rollers I used iron rollers (just found them in the drawer) but if you are planning to roll it on the table, use the plastic ones.
    I planned it, to leave some 1/16" between the Horizontal rollers and the fence, and then, I tight the rollers to the fence with the "Bolts".
    The travel, is limited by your fence length (maybe I'll make longer fence).
    It's rolling nicely without any side play and the test results (on the pics) were excellent...now I have to find some project...
    And the rest is on the pictures
    Regards
    niki
    Re: "Rolling" Tenon jig for TS
