3650 arbor and Freud SD208
  • 3650 arbor and Freud SD208
    I just bought the SD208 dado set. It has a very tight tolerance around the arbor hole. Slipping it on and off the arbor of my ts(3650), I have to spin each blade. Anyone else get this before?
    DAN
    Re: 3650 arbor and Freud SD208
    Take a little sandpaper and gently clean out the bore a bit and see if it helps.
      I have the same set, and they went on ok. The fit was snug, though.
        A snug fit is needed to help ensure that the blades make as flat a bottom cut as they can. A loose fitting dado set would be a bad thing.
