trim bs tire
  • trim bs tire
    What is the best way to trim a rubber band saw tire?
    DAN
    Re: trim bs tire
    What do you mean by "trim"
    “If there must be trouble, let it be in my day, that my child may have peace” - Thomas Paine
      Re: trim bs tire
      The rubber is wider than the aluminum wheel by roughly 1/16th. If I tuck it in it forms a bump in the middle. Also the tire is thicker than the lip of the wheel so that bump becomes quite large. I need to trim the width and true the tire.
      DAN
        Re: trim bs tire
        I'm new to this forum, but to answer your question. If you have an owner's manual look up the rubber wheel part number and order a new one. If you try trimming there is no guarranty the wheel will remain perfectly round and (if I understand correctly) you risk breaking the saw blade.
