TS2424 Caveat
  • TS2424 Caveat
    When tilting the blade angle from 90°, you first back off the spring-loaded blade lock, as you probably know. What you may NOT know is that if you leave it in the approx 12 o'clock to 3 o'clock position, you can bend the bolt the spring-loaded handle engages. This happens as the handle pivots into the TS top.
    A better design would be to have a round/star-shaped wheel centered on the tilt crank.
    rotsa ruck & bee safe
    Rodney J in TX
    Isn't this covered in the manual?
      A star knob on the bldae tilt is nothing more than a nukle(sp) buster!
      Andy B.
