TS3650 Outfeed
    Re: TS3650 Outfeed
    Originally posted by Boogatoo View Post
    I made my extention based on the plan in Best Ever Workshop Solution 2006
    Get the Wood Magazine Best Ever Workshop Solution 2006 (reprinted in 2008 due to popular demand). 7.95$ http://woodstore.net/bewoso.html or part of a trio for 12.95$ at http://woodstore.net/saonthgrmafu.html
    It features 1 1/2 inch L iron bar attached to the wings (no drilling requested) because the wing is sandwiched between the L bars and a 1/8 inch flat bar on top (in 1/4 inch the ressessed space) of the wing.
    The leg is removable and snaped in broom holder when not in use.
    Leg length is adjustable (T-nut inserted in drilled dowel, a srew is used as the leg adjustment.
    Used Wing-nut to lock height in place (my idea).
    Dowel is driled sideway to lock when in use (my idea).
    From the front of saw to the back of the extention table, it mesures 5 foot 3 inches.
    I used birch plywood and covered both side with melamine using waterbased contact cement. Finished exposed plywood with Danish oil (equal parts of mineral spirit, urethane and linseed oil). I built it in a weekend.
    This looks like exactly what i want to do but I am not quite getting how you attached the L bracket to the saw for mouting the table to. I see it in your pictures but what is the L bracket atached to? I have the 3660.
