4424 Sander
  • 4424 Sander
    Jake thnx for the reply, however the part in question is on the back side of the edge belt,
    key #12 - "Plate Wear" from the parts list. It is made of plastic or composite material ??
    and as I said before, the bottom 1/2" of the belt is rubbing on it and has removed 1/16" +/-
    so far. The part is used to align the belt to the miter slot and I have tried to adjust it out of
    the way but that sets the alignment off. I'm anxious to use the sander but a little apprehensive
    as I'm not sure how much material will be removed and will it then loose its effectiveness.
