TS3660 Extension Tops
  • TS3660 Extension Tops
    Just wondering if anyone that has bought the 3660 has had a problem with the extension tops not being perfectly flat with table top. Mine seem to go up on the outer edges of both extensions. Has anyone shimmed theirs? I have a machinist background and I like for things to be very close. I have a few other adjustments to make everything as close as possible. I think I am going to like this TS3660 but who wouldn't coming from a Craftsman 10'' direct drive 10 years old.
    Re: TS3660 Extension Tops
    Check out the thread 'Problems bolting extension tables to TS3660', found in this forum at http://www.ridgidforum.com/forum/showthread.php?t=16275
      I had the same problem when assembling mine. I ended up using a c-clamp the bring the main top flush with the wings and then tightening the center bolts.
