Arbor play on TS3650
  • Arbor play on TS3650
    Hi,
    I am trying to set my blade parallel to the miter slot using an A-Line-It jig set. Proving to be a challenge. As I tighten the trunion bolts up, the trunion seems to move a little bit. I am within 2 thousands now but my question has to do with the movement of arbor. Exactly how much should the arbor assembly be able to move when pushing on it laterally (away from the fence)? Mine will move over 15 thousand's of an inch when pushing on it with low to moderate force.
    Thanks.
    -k
    Re: Arbor play on TS3650
    sounds like too much play.
