Using a Dado Blade with the Ridgid TS2400LS table saw
  • Using a Dado Blade with the Ridgid TS2400LS table saw
    Hi everyone,
    My name's Jim and I'm a newbie here. I have a question regarding using a dado set with the TS2400LS table saw. According to the manual, a dado set up to 13/16" can be used. The manual says to remove the inner washer and spacer, then to re-install the inner washer. Unless I am seriously missing something, The inner washer is fixed. From what I can tell, it is what you put your wrench on to hold the arbor while removing the nut. Any suggestions or advice is greatly appreciated!
    Re: Using a Dado Blade with the Ridgid TS2400LS table saw
    Please see the end of thread "TS3650 Arbor". Several important posts are there.
    Maybe we should copy the relevant post to this thread.
