Aux Fence and rail scale
  • Aux Fence and rail scale
    When an aux fence is attached should I slide the rails to the right and "zero" out the rail scale or just use a tape measure to locate the fence or just use a nominal measurement that is close to the width of the aux fence material. I am just curious about this and probably all of these are acceptable. But I would like to hear other more experienced woodworkers opinion on this as I am sure I will. Is the aux fence just a protection device to keep the blade farther from the fence and keep the chance of a blade/fence strike down?
    I wouldn't mess with the rails once I had them set correctly. The "aux" fence is usually just a temporary set-up used when the fence needs to be set close to the blade. If I need to I use a rule to set the aux fence.
