adding a riving knife to a 3650
  • adding a riving knife to a 3650
    anyone know of a way or have done it, add a riving knife to 3650?
    jer
    Re: adding a riving knife to a 3650
    I don't know for sure and could be wrong but I don't believe adding a riving knife is possible without some major modifications to the saw.
      Dave's right...not an easy task, but you can add a nice aftermarket or shopmade splitter. There's nothing magic about a riving knife. The riving knife's biggest advantage is that it's more likely to be in place when needed because there's less reason to remove it. It rides up and down with the blade and is a little closer to the blade. The RK is a more elegant design than a typical splitter, but it still performs the same basic function.
      You could look into a Sharkguard or Microjig Pro, or build your own splitter.
      Here's one my brother made for my 22124 hybrid:
ID:	615742 Click image for larger version
ID:	615741 Click image for larger version
        Interesting add-on, hewood. Did your brother make a pocket-bracket which you bolted to the trunion or other part of the undercarriage? Nice addition. I'm trying to picture this on a 3650.
        Later,
        Chiz
          I doubt if there is enough room behind the blade on the 3650 to accept a modification like the one on hewood's zipcode.
            One big difference is that the riving knife moves with the blade, so the gap between the blade and the knife is always the same. This helps eliminate kickback far better than the splitter does.
              I sure wish there was a way to add a riving knife. I was wondering if you created several zero blade inserts and added a splitter depending on the height of the blade. Say for ripping 3/4 inch plywood the blade is only a inch high and the splitter added closer to the blade. For a thicker board a separate insert would have a higher blade height and the splitter farther back on the insert.
              The splitter could be a 1/8 hardwood or after market plastic thing.
                A fellow woodworker named Bob Ross makes a "Push/Pull" splitter, and "BORK" (Bolt On Ripping Knife). The BORK is essentially a riving knife that rides up and down and tilts with the blade, but he only has models for a handful of saws...Grizzly/Shop Fox cabinet saws, and Steel City and Craftsman hybrids at this time (AFAIK).
                walnutacrewoodworking.com/Online_Store.
                The main advantage of a riving knife over a splitter is that it's more likely to be in place....a decent splitter works fine most of the time if it's left on the saw. The closer proximity to the blade is also a benefit of a riving knife, though I don't see it as the main advantage.
                  I have been thrashing this around in my mind for a couple years now, how to put a riving knife on the TS-3650 that is. I have an idea or two which I want to try out. It would be pure bolt-on and 100% reversible with no damage to the TS. What I have in mind would means that an alternate way to install a guard would be required, or an overarm guard would have to be used.
