DAdo Blades
  • DAdo Blades
    I have a 10" Compound Mitre Saw from Rigid. I would lik eto run a Dado blade on it. Can this be done?
    also,
    What is the Maximum groove one can cut with a single pass on a dado?
    Wrong tool! While I've seen dados cut using a slider, they don't use dado sets---just the stock saw blade. It's just not a great idea, even if the stacked set would fit, which I don't think it would. Use a router.
    Dave
      SO your saying a router is the better animal?
      I'm willing to go with that. question is:
      What is the largest "groove" one can cut with a router and secondly. how deep and wide can you go on one pass?
      I need to make a groove approx. 1" deep x 2" wide.
      I'd like to do that in one pass.
      Thanks
        Originally posted by Xrossed:
        .......... I need to make a groove approx. 1" deep x 2" wide.
        You could make a jig to make that cut with a router but I certainly wouldn't recommend that you make a cut that deep in just one pass.
        [ 04-06-2005, 09:46 AM: Message edited by: badgerdave ]
          ok... So, Ill make more than one pass.
          Ill need a router table. what kind of bit? and what size?
            Lots of great information and helpfull hints at Pat Warners' website.
