Part needed
  • Part needed
    Hi all, I have an old Delta 36-220C compound miter saw. It recently took a hard fall and broke the part that locks the table into all of the pre-set angles. Delta no longer provides the part. Does anyone have one of these saws with some other problem that makes it non-functioning? I would love to repair the saw but so far no luck.
    Thanks in advance
    David
    Re: Part needed
    You might look here- http://www.toolpartsdirect.com/cgi-b...6-220_TYPE_III
      Re: Part needed
      Thanks, I hadn't found that site before - the part is marked Obsolete - no Replacement. I have contacted to company to see if that means it is actually available.
      Thanks again
      David
