DP1550 idler pulley
  • DP1550 idler pulley
    I have two questions about my new drill press.
    1)the idler pulley seems to be unfinished, it sits about 1/8 higher than the other two pulleys.
    2)did I push the chuck far enough on the spindle?
    thanks in advance
    Phillip Hsu
    Hsunami,
    The pully should be just about even with the other pulleys. There is a shoulder on that shaft, but it should be even all the way around. Drop me a line via email and I will take care of it.
    The chuck is on correctly. On a taper fit, you do not need to press it on like you would a bearing and a shaft, you only need to seat the two tapers.
    Jake
