TS2400 - cleaning around the motor
  • TS2400 - cleaning around the motor
    I have the TS2400. I've noticed the Ridgid stand is open below the saw. Mine is mounted on a rolling cabinet for a stand. It works well,but solid top doesn't allow the dust to fall. I clean around the motor, with air, after each use. My question is, will a solid base lead to problems, such as heat build-up or trapping to much dust, etc. Any advise is appreciated. I am new to the forum and am not sure what the graemlins and UBB code is for. I hope this works.
    Sriver,
    Welcome to the forums. If you are using a dust collection system, I wouldn't be concerned about dust. Additionally there are enough gaps in the housing to allow air in to cool the motor, so heat shouldn't be a problem.
    Jake
    [edit]needed to fix a signifigant typo (shouldn't instead of should)
    [ 12-10-2002, 09:22 AM: Message edited by: JSchnarre ]
      Jake, Thanks.
