Router lift
  • Router lift
    Good day
    After I made the Mortising jig for the router table, I thought that to bent under the bench every pass to lift the bit, is too much for my old back so I made a simple lift.
    The lifting mechanism is located behind the fence so it does not have to be removed after every adjustment and will not interfere with any operation.
    It takes some 30 seconds to install it and I'll probably improve a few things with time and experience.
    It works very smooth and takes some 30 turns from "bit level with the table" to "bit 1½" above the table".
    It's not my normal "how to" just a short one (I have also a long "how to").
    I think that with a little bit of imagination, this router lift can be fitted also to a "normal" cabinet router table.
    Regards
    niki
    Re: Router lift
    Now that might just be my favorite jig from you Niki, way to go....
      Re: Router lift
      Thank you so much Garager
      It makes me to feel so good that you like it and find it helpful
      Regards
      niki
